Old 05-29-2023, 12:27 PM   #1 (permalink)
ttrainxl
ECU choice for ‘95 Honda Civic
I have a stock ‘95 Civic Ex with the D16z6 and a 5 speed transmission. I’ve been getting anywhere between 39-44 mpg, depending on the temperature outside. I just bought a D15z1 long block from the junkyard. (For the non Honda guys, this is from the Civic Vx.)
My plan is to put the D15z1 head on the D16z6 block. I don’t want to swap the entire engine in for now. Swapping the head will bump compression up to 10.7:1 with a thicker head gasket. I’d like to make about 100-110 hp with this setup, rather than the miserable 90hp stock D15z1 engine provides. I don’t have the P07 ECU yet and I’m wondering if a chipped P28 with P07 fuel maps would give me more tuning ability. I know almost nothing about tuning but I’m curious if a chipped P28 and possibly Hondata will open up a little more power and fuel economy that a stock P07 ECU would give me. It seems that if you can tune an engine for more power, you should be able to tune for more fuel efficiency as well.
Anyone have thoughts on this? I’m aware of the five wire O2 sensor issue and I’m aware that my engine will be running in Vtec at 70mph and that I need to swap a transmission, or preferably (after looking at D series transmission gear ratios), keep my transmission and swap in a lower final drive. Right now I’m only asking about the ECU options.
Any help is much appreciated. Thanks.
