New member here too. I also have a Civic EX of the 2012 flavor. I installed rear camber arms and set camber to zero as well. The old tires were howling like crazy because of the camber. I set camber and toe to zero on the front also. My tires are wearing perfectly. I will check back to see how your wheel covers are working out.
2000 Honda insight
Full boat tail in work
EPS delete including pinion gear
Interior delete, trim, carpet, everything
Radio delete
Rear wiper and motor delete
A/C delete
FAS switch
Calpod switch
10 ah LIFEPO4 battery
Upper grill block
