Old 06-02-2023, 10:26 AM   #485 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Assuming you're talking about a Jerry can, having to stop at a roadside (or no roadside at all) to pour fuel from a Jerry can to the tank wouldn't be something so pleasant to do here.
That would be the simplest way to add extra fuel range when required. An auxiliary tank would also be a simple option to add if you routinely need to go more than 100 miles without stopping. It would be a simple gravity feed system with a manual petcock to switch tanks as needed.
Either is a better option than simply not being able to make the trip because the bike can't maintain the speed limit.
