Thread: Ecomod my gx390
Old 06-03-2023, 02:59 PM   #7 (permalink)
oil pan 4
Oh yeah its a full rebuild.
Got a standard bore block, file fit rings, a 0.01'' head gasket.
The standard head gasket is 0.45''.
Thinner head gasket should bump the compression about a half number, from 8.2:1 up to 8.7:1 and I think I'll get a 2 and 4 degree timing advance keyway.
Since it will be a pressure washer, or just a pump it's perfectly testable. Hold the throttel wide open and more RPMs means more PSI and more GPM. PSI x GPM is power.
