Old 06-05-2023, 10:57 AM   #215 (permalink)
Blacktree
Blacktree's Avatar
The Prius Experiment - '07 Toyota Prius Base
90 day: 58.52 mpg (US)
Not much going on with the Prius lately. Although it did reach a milestone (200k miles). And I think the other front wheel bearing is going bad.
On a side note, I think the next eco-mod will be a belly pan. My local Home Depot sells coroplast in 4x8 foot sheets. Last time I was under the car, I saw lots of existing screw holes that can be used to mount it. That'll make the job easier.
That said, I got some polycarbonate windows (aka Lexan) for the BMW. So we're going to install those first.
Another side note: The weather here in Florida has been unusually mild. Normally, daytime temperatures would be in the mid 90s by now. And I'd be running the a/c all the time. But we've only had a few days where the temperature reached 90 degrees. So I've been using the a/c intermittently. As a result, the fuel economy has been outstanding. Actually, last week was the best fillup to date, with almost 68 mpg!
