Old 06-05-2023, 12:09 PM   #15 (permalink)
aerohead
Silverado aero
When you get a chance, take a look at General Motor's 2013, Holden Commodore VT Ute.
It's kind of like the El Camino and Ford Ranchero of the past; passenger car-based 'trucks'.
The VT is Cd 0.309, the lowest drag of ANY 'truck'
Anything they did would be fair game for the Silverado, except the tonneau cover. Your aeroshell will have a drag advantage over the tonneau.
* You may be able to block off some of the radiator inlet.
* A full-sweep, wrap-around airdam, as low as the lowest part of the belly, excepting the differential's pumpkin, all the way to the front wheels dates to 1974.
* Rocker panel extensions to matching depth.
* Electric cooling fan if it doesn't already have it.
* Any belly pan you can stand. Begin at the front and work rearwards.
* There may be better side mirrors available since 2010.
* I've got rear skirts, and they've never been 'in the way.'( as low as the belly/ rocker panels )
* A rear diffuser typically requires a full belly pan ahead of it ( one race car website offered a countervailing viewpoint ).
* Low-porosity wheel covers which allow for brake cooling.
If the aeroshell were to become a PITA as far as 'hauling' goes, a half-tonneau, plus cab-wing extension offers more bed access, and only about a 2% drag penalty, comparatively.
If you and your's ever go in the truck on a longer road trip to 'grandmother's' on holiday, or such, a receiver-hitch mounted boat-tail extension can add another 4-mpg.
https://fastcars.com.au/products/hol...re-2013-vf-ute
Waspswatter (06-07-2023)
