Old 06-13-2023, 04:03 AM   #1381 (permalink)
Xist
I was accepted for a house, but Progress Residential is rated 1.07/5 on BBB, and had 1,619 complaints...
...over 3 years.
For some reason the Better Business Bureau's site went down for hours, right after I started reading reviews.
This says they are horrible: https://pestakeholder.org/news/progr...ng-conditions/
They had 26,000 houses in 2018, but have 85,000 now.
Invitation Homes had 80,000 in 2017 and 83,000 now.
They also have a 2.7/5 rating and 954 complaints, so they sound bad, but not nearly as bad as Progress!
I couldn't find the owner of the house with a Zillow application and the one that I liked the most isn't registered with the BBB.
Then one is with Invitation and 2.7/5 with 954 complaints sounds bad.
Once again I was planning on driving down today, but since I had hosed off the floor mat with the pancake syrup I wanted to vacuum the carpet before putting back the mat.
My portable upholstery cleaner happened to be right next to my shop vac and I needed to clean it before donating. I figured that I might as well use it one last time before cleaning and donating. It pulled up dirty water, but I filled up the clean water tank and maybe used a couple ounces with my passenger seat and the floor in front of it.
In theory I could clean my entire car and still be about full, so I dumped out the water on my passenger seat and the carpet, and half-filled the dirty tank with dirty water.
I seemed to get just as much water with my shop vac after using the upholstery cleaner, but I sure wish I had cleaned the shop vac before I got it wet!
Then I started receiving e-mails from Progress and looked up their reviews.
Do that first, okay?
