Old 06-16-2023, 12:14 PM   #20 (permalink)
EcoCivic
Thanks. What is the switch attached to? Does the full output of the alternator go through the dashboard? Momentary push button or toggle?
I installed a toggle switch in the blank filler next to the fog light switch, I'll try to get a picture of it later. The switch doesn't carry any measurable amount of current, it's just interrupting the signal wire telling the voltage regulator to turn on when the ignition is on.
The Following User Says Thank You to EcoCivic For This Useful Post:
freebeard (06-16-2023)
