Old 06-26-2023, 01:19 PM   #2 (permalink)
freebeard
Thank you for your attention.
Some of this will need to be defined
1) through 3) to be determined
4) Breakover angle is 20 degrees on a 75" wheelbase
5) is 62"
6) through 11) to be determined
12) through 16) dependent on class rules.
https://external-content.duckduckgo.com/iu/?....&ipo=images
One 'cafe racer' saddle, foot brake moved to the rear, handlbars inverted. Blister canopy may be required unless the handlbar shaft can be shortened and the motor controller moved
Ignore the fourth wheel; that was to fit class rules.The rear truncation (I believe) should be like this:
Modified to contain the suspension and wheel.
I hope to get over to the Westside this week, for information gathering. Mostly for putting a drivetrain/suspension in the back of my '58 Baja bug.
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
aerohead (06-26-2023)
