Old 07-06-2023, 11:34 AM   #7 (permalink)
oil pan 4
As far as I can tell little engines like these don't have a crank pin like a bike engine. It's all one solid piece.
If you put a +2mm stroker crank increased displacement to 471cc and that would reduce at the same time reduce chamber volume 6cc and would give you a compression ratio of about 10:1.
If they tried to fill the hole by moving metal to the too of the piston you can only move about 6cc of metal, that's about like making a little over 10:1 compression the piston 1mm do in in the hole with a little 3cc hemi ridge.
That's assuming the stock engine is 9:1 compression with 51cc of total chamber volume, that's down in the hole plus head gasket plus chamber volume.
