Old 07-07-2023, 10:14 AM   #8 (permalink)
Piotrsko
The welding technique makes things offset by adding material on one side and re machining the part to standard when you cant remove it from whatever it's attached to, next best description is regrinding a cam shaft for more lift, but not quite the same.
In the late '60s Iskaderian would take your factory stock cam, weld onto the lobes and regrind it any way you wanted
