Old 07-07-2023, 11:55 PM   #3 (permalink)
redpoint5
90 day: 38.47 mpg (US)
Originally Posted by MurrayRothbard View Post
Noobie here getting in to hypermilling. I see many people using devices such as the ScanGauge II which runs about $200. Doing research I see the Torque App ($5) and a cheap Mini Bluetooth OBD2 reader (~$15), do you think it would give the same MPG accuracy as ScanGauge II? It would appear its getting the data from the same source so I dont see why not, and I got a spare android to connect it to. Opinions on such device?
Takes some dialing in, but I think it can be fairly accurate. I never put in enough effort to dial in that accuracy. For instance, the Torque app has a parameter for volumetric efficiency. I don't know what that is, so I went with the defaults.
