"While Coroplast® will burn, it does not have a flash point or an uncontrollable flame spread rate like some acrylics or styrene."
And what of heat transfer on that heat shield I mentioned ? I plan to use aluminum sheeting.
Edit - scratch that.
So I assumed that aluminum had less of a heat transfer rate than steel. Whuups.
