Old 07-13-2023, 11:23 AM   #6 (permalink)
aerohead
'plastic belly pan'
Dr. Teddy Woll of Daimler-Benz, in 2014, wrote that the entire exhaust system of an internal combustion vehicle could be thermally insulated to facilitate enclosing the entire length of the underbody.
One would need to use commercial/industrial insulation products as Knauf provides.
They're not a 'retail' product that a 'civilian' can walk into a store and purchase.
With a 'business card' they might let you through the door.
Short of that, you might be able to just rely on metal heat-shields/ multiple heat shields as you may see above and below catalytic converters.
American ICBM missile silos use sixteen concentric metal heat shields around the missiles to stabilize temperatures. The company in Dallas that I used to work for was a contractor to the Pentagon for working around technology like that.
You need about a half-inch air-gap between shields. And some can be attached to the upper face of the coroplast if you can't do hangers from the exhaust system above.
I was able to use 1/8-inch thick Luan door skin on the Spindletop CIVIC CRX by doing this.
I don't see why the coroplast would be a problem.
Cd (07-13-2023)
