Old 07-14-2023, 10:01 AM   #12 (permalink)
oil pan 4
Yeah and there's no roller bearing on the crank.
The only reason to give up rollers and go with flat bearings is if you are going to gain a cross drilled crank with a very tight fitting rod, like 2 thousands.
