Old 07-19-2023, 01:29 PM   #5 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Yeah if that Volt got the infamous “battery longevity update “ you likely get to look forward to
Much less battery capacity
Much less range
Much lower winter fuel economy
Generally your battery should show 10-10.5kwhrs new (on the screen)
The Volt is like the Insight in that you need the OEM tires and 50psi to get the best experience.
If you want to get some of this back I recommend finding Brian Baptista and the Volt diy repair, Volterado tune and diy programming facebook forums
Brian has enabled ELR mode in a diy setting which gives back some lost range and the Volterado tune although in beta enables lean burn on e30+ fuels with a tune.
As for “easy” mods any EVSE can be modified from 120vac to 220VAC if you cut out the neutral wire so you can choose a 110vac end or 220VAC end.
Thankfully most EVSEs these days don’t need that extreme of a mod, some have a switching supply and are 220 ready out of the box, others like the 2013 Voltec clipper creek EVSE require a minor internal mod.
Good luck and have fun with your new car
The Following 3 Users Say Thank You to rmay635703 For This Useful Post:
aerohead (07-20-2023), Daox (07-20-2023), MetroMPG (07-19-2023)
