Won't that double the power required?
It had a 6.5hp 200cc class motor and was underpowered, now it's got the predator 459cc and is over powered.
If running 2 cutters on makes a problem I can always under drive the the cutter head. Now it runs about 87% of crank speed now, I could reduce that down to 75% easy.
Also I am going to get a little more power by advancing the timing and increasing the compression ratio by a half number.
