Old 07-24-2023, 01:40 PM   #133 (permalink)
CigaR007
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
I like the idea of skirts that flow all the way to a separation edge. If they're light, then why not big?
Yeah that seems to be the ideal approach, especially with an added rear diffuser. I see lots of tuft testing once the rough shape is built.
So I ordered 2-part polyurethane foam this morning. My plan is to try and pour 2 or 3 times to form a somewhat rigid single foam block. I believe this approach will cut down on the time needed to carve out the desired shape/taper. It involves more preparation prior to the pour, but the result will be cleaner.
For the time being, I will build a rigid box, between the tail lights. Once the 2-part foam is received, I will proceed to fill the side tapers and the upper part all the way to the third brake light.
I will include a drawing later this evening.
Cheers.
The Following 2 Users Say Thank You to CigaR007 For This Useful Post:
aerohead (07-31-2023), freebeard (07-24-2023)
