Old 07-26-2023, 05:33 PM   #134 (permalink)
CigaR007
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
View from above, in order to visualize the taper.
View from above, with the inner box.
At this stage, I would fibreglass the structure to strengthen it, but I am out of epoxy resin...
The 2-part polyurethane foam arrives next Monday, so no can do on that front until then. It might be a good time to start visualizing the tapering and curvature. I need to find a way to visualize/confirm whether or not the rear top corners of the box are inside or outside the optimal taper.
What do you guys think ?
Cheers.
The Following 2 Users Say Thank You to CigaR007 For This Useful Post:
aerohead (08-13-2023), razordave (08-25-2023)
