Old 07-29-2023, 04:25 PM   #137 (permalink)
CigaR007
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
So I hit somewhat of a snag while looking at the rear diffuser. The entire structure was slanted towards the rear. Newbie mistake, as I was mostly working at an angle, the car being on plastic ramps. I figured a way to shim the whole structure without much hassle though. Still has a slight slant, but it is good enough ..as they say. Lesson learned...
I added a smaller box in order to reduce the amount of 2-part foam needed. I also fixed the tow bar rattle/play with a u-clamp.
Started visualizing the curves and taper.
Cheers.
The Following 5 Users Say Thank You to CigaR007 For This Useful Post:
aerohead (08-13-2023), alexshock (07-30-2023), BamZipPow (07-30-2023), freebeard (07-29-2023), Joggernot (07-30-2023)
