Old 07-30-2023, 11:10 PM   #12 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
I didn't want to buy expensive, heavy-duty jack stands, but I also didn't want to die, so I made some tripods from 2 X 4 studs. They are working fine. Lifting is done in stages so that a power drill can do the work on a scissors jack.
YouTube has many clips about making ramps, mostly wasting a lot of wood, but the featured improvement is hinging the thin ends so they can swing out and not restrict access. It occurs to me that one could make a whole series of sloping blocks and drive a foot at a time, adding bigger blocks in front of each tire and moving shorter ones to the following tire.
I got over a year out of a plain fiberglass bandage on the exhaust pipe, and the problem is probably new holes. "Use it up, wear it out, make it do, or do without."
The Following User Says Thank You to Bicycle Bob For This Useful Post:
MetroMPG (07-31-2023)
