Old 08-05-2023, 12:03 AM   #23 (permalink)
JacobLeSann
Bad news, didn’t get it all done before the sun went down. No tuft-test photos of this section of the build.
I like the look of the Fusion LSR, as well as several landspeed record cars I’ve seen. I made it even closer to the wings they use by adding a pair of spill plates. I think it looks funky and I like it. I understand the spill plates are for straight-line stability and can generate vortices as they slice through the air, but I put ‘em on anyway. I like em.
Iirc, I read through a rallycross aero article about wing design, and the wings that didn’t use any spill plates had poor performance, due to air falling off the ends. I wonder if that applies; I noticed consistent flow down the rear windshield as well as tufts converging from the C-pillars to the centre line of the rear glass. Either way, the flow is good indeed.
The stability seems improved as well. I don’t have my belly pan/airdam attached right now, and I noticed front end lift as well as oversteer at around 170 km/h turning a hard corner. On that same corner, I attacked harder and didn’t feel any lift off; front or rear.
Now to do it all again in coroplast! Big test run comes tomorrow morning!!
ID:	34036   Click image for larger version
ID:	34037   Click image for larger version
ID:	34038   Click image for larger version
The Following User Says Thank You to JacobLeSann For This Useful Post:
kach22i (08-05-2023)
