Old 08-13-2023, 08:06 AM   #10 (permalink)
j-c-c
For 1999 Dodge Dakota.
Because the ones I can buy are expensive, look stupid, don't do what I need, stick way up above the cab, are right up against the back window, ect.
To have it be aerodynamic it will have 2 key features.
It won't stick out or above the cab.
Not be there, easy for me to remove but no one else, 4 bolts.
My leaf light bar tests showed at least a 20% range reduction when putting something above the car.
My list of requirements are:
Not be made of exhaust pipe.
Be made of thicc steel tube.
Not further degrade the barn like Dodge aerodynamics.
Have a stand of at the top for reasons.
Also offer back window protection, expended metal.
Attach to the sides of the bed not down in the bed, for maximum carrying room.
Well, in order to assist, a few details should be sorted out to better understand your overall objectives here.
You have mentioned a few "requirements", but knowing why is also useful ie, define the problem.
For instance: "Thick steel tube", why?
Define "stand", and why?
"Back window protection", that seems redundant as that is what a headache rack is mostly.
Attachment to the sides and not to the bed base seems to make "thick steel tube" rather superfluous IMO.
Any aero concerns are addressed here mainly by two aspects, do nothing to increase frontal area, and minimize any gap between existing cab and headache rack, which seems to state you dislike, everything else is mainly cosmetic and functionality. Adding fixed lights on top negates any and all aero achievements achieved elsewhere and changes the main design IMO to a headache rack that is a light mount. Make the desired headache rack longer longitudinally for improved aero takes up bed space that is not acceptable for "maximum carrying room"?
This is my take based on what is shared so far on the project.
