Old 08-13-2023, 05:31 PM   #144 (permalink)
CigaR007
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Is there a plan to fabricate Plex or Lexan covers to cover the void behind the taillamps?
This area is critical with a fastback body. It needs the tumblehome and curvature to mitigate formation of vortices, blending the 'sides' into the 'roof.'
If you can't do it, you might as well foam the whole area in, on both sides, and put a trailer light kit on the back of the tail.
According to Jeff Powel and associates in England, you could be introducing, something on the order of a 33% drag liability.
Lexan covers is an option, just not sure how to work with it, in order to achieve the desired shape (heat gun ?).
Filling with foam is also a possible scenario.
Been also considering vortex generators just before the taillights, as to force the air to "hug" and re-attach onto the upper kamm tail side wall. A tuft test might shed some light.
The Following User Says Thank You to CigaR007 For This Useful Post:
aerohead (08-13-2023)
