Old 08-14-2023, 01:42 AM   #11 (permalink)
razordave
Plot twist..
I looked at the 'visor' at as much magnification as I could get, and it appears that the forward leading edge is 'open' to the airstream. Is that correct?
You are correct. I did not know about the air flowing forward. That could explain that previous tank being horrid.
If I reinstall the visor, I will tape the leading edge. The mounting hardware caused this gap. Attached is what I thought could be a slick easily removed mounting solution.
Free beard, I couldn't remember where I had seen a similar setup but had actually reviewed basjoos thread last night when I decided to begin planning a boat tail or at least a truncated one.
Did I read somewhere that 40% will give you 80% of the benefits?
Lastly, I got a lead on an estate with old airplanes. I may blow a circuit with a body swap on the old tdi..
Edit: it has been done with a pickup chassis and a delivery truck chassis and I'm sure a few more.
https://youtu.be/DHyZPVOT1xI
After having seen some people chop up a beetle to build small campers...
Name:	Hangman-Heavy-Duty-Mirror-Picture-Hanger-100-lbs_5986c7cc-2834-4d87-a911-0bcec64c5489.22112ab450.jpg
ID:	34059   Click image for larger version
The Following User Says Thank You to razordave For This Useful Post:
aerohead (08-14-2023)
