Frank -
Originally Posted by Frank Lee
I have a Simple Device Which Uses Electrical Field Will Boost Gas Efficiency Up To 20% Or More... it is a tachometer controlled microswitch, set to activate at 2000 rpm. It energizes a circuit which consists of a cattle prod transformer with the outputs connected via jumper cables to your privates. Another incorporated function for circuit activation is a WOT switch. Cheap, effective. Wanna test it? :P
It's already on the market (of the future), and it won't even run down the battery! :
Magnavolt
CarloSW2
