Old 08-27-2023, 06:57 PM   #61 (permalink)
Caddylackn
Passat TDI Wagon - '97 VW Passat Wagon TDI
90 day: 51.24 mpg (US)
Blue - '21 Hyundai Sonata Blue
90 day: 47.54 mpg (US)
Next thing I added was front skirts, from left over pieces of the Ford hood. I mocked these up in coroplast to fit around the bumper first then traced to sheet metal, then tack welded, cut and fit, and finished.
This was glued and a couple screws to hold it, incase the glue fails
You can see the exit came out good, about 5/8". Front scoop is pretty big because of the bumper transition, I may close it in a little later. The skirt side pieces fit attach between the upper and lower bumper. Being steel, I just jammed them in there between body panels with some elastomeric type glue and a screw for security.
I then closed in the front wheel openings with coroplast and more sheet rock steel corners and added the side dam under the car to guide the flow from getting sucked under the car. It all lined up pretty good. Spray bomb matt black.
Last thing I did was some ghetto window tint for summer to keep the temps down so I could drive without air conditioning.
ID:	34109   Click image for larger version
ID:	34110   Click image for larger version
ID:	34111   Click image for larger version
97 Passat TDI Wagon
Bosio 520 DLC nozzles, chip tune
Mufflerectomy, ALH Injection Pump
317k miles
Scan Gauge II
full belly pan
26 gallon tank
The Following 2 Users Say Thank You to Caddylackn For This Useful Post:
freebeard (08-27-2023), Joggernot (08-27-2023)
