Old 09-07-2023, 11:32 AM   #762 (permalink)
aerohead
'stylized'
Originally Posted by Phase View Post
The pointy shape is just an extension of the originally OEM hard separation edges that Hyundai already tested in the wind tunnel. I didn’t want to alter the rear side shapes because I have no idea how it would affect up wash or down wash or wake shape. I cut the inside shape to add a more stylized sporty look. In all, it’s just an extension of the original sides from Hyundai. The poster board tests with the same shape and duct tape already gave me a 4 extra mpg boost from testing before.
I'm just saying that, if you have a constant-contour in these 'fins', that, at the trailing edge, there will be a mandatory difference in velocity and pressure, which will introduce vorticity, something which would not occur if you simply made the trailing edge 'vertical', like Koenig-Kamm did in the 1930s.
Hyundai/ KIA / Genesis is going to do exactly this next year on one of their big SUVs.
' ... angled inward...the airflow remains attached until the trailing edges...the resulting wake will be smaller.' Julian Edgar, 2018, p.131
' A wide wake does not necessarily imply a low rear end pressure; in fact, the reverse can be true.' Julian Edgar, 2018, p.11
( Another contribution to drag arises from trailing vortices...) Julian Edgar, 2018, p.11
' Trailing vortices are shed by angled, upright edges...' Julian Edgar, 2018, p.17
' The flow separations that lead to a pressure drag can be... inclined separation line flow separation shed vortices with axes roughly parallel to the separation lines with well-ordered, steady three-dimensional flow separation on the rearward surface, inducing a suction which leads to a pressure drag.'
Hucho, 1986, p.59-60, 2nd Edition
