Old 09-12-2023, 08:01 PM   #26 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Simon TT View Post
I don't exact know the internals of my gearbox, but replacing the reverse gear with a motor should be possible, if not I could mount the motor externally
I'm well aware of some replicas of the Lotus 7 fitted with motorcycle engines resorting to an auxiliary electric motor only to provide reversing, not being a hybrid at all. Maybe you could remove the reverse gear from the stock transmission of your car, which I wouldn't recommend, but I don't believe replacing it with an electric motor right inside the transmission case would be any easy.
