Old 09-17-2023, 05:33 PM   #34 (permalink)
oil pan 4
Looks like it's already got a thin head gasket so no gains there.
I put the 8 degree timing advance on and put the intake and throttle linkage from the briggs and Stratton 208cc engine that was on the woodchipper.
Starts and runs great with 8 more degrees of timing.
The Kohler intake looks smaller, more restrictive because it has additional unnecessary 90 degrees bends. The Kohler intake was only bolted to the carburetor.
The B&S intake also bolts to the throttle linkage plate with a 3rd bolt.
With only 2 bolts the Kohler intake would vibrate independent of the rest of the engine.
Now the intake vibrates in unison with the engine.
Seems like only a matter of time before it would vibrate loose and allow dirt onto the engine.
Also modified a spring to turn the RPMs up to 4,000.
