Old 09-25-2023, 11:07 AM   #15 (permalink)
Logic
"...Use of In-Cylinder Catalysts
In order to investigate the application of the concept of
catalytic combustion, various catalysts, such as copper,
chromium, and nickel, were coated on the combustion chamber wall or determining their effects on engine
pcrtormance. combustion, and emissions characteristics...
...Among the
different catalysts investigated, copper was found very
effective in reducing both HC and CO emissions, and brake
thermal efficiency was also improved. At a high CR of 9:1
and with a lean mixture (A/F=15.7), copper catalyst increases
the absolute brake thermal efficiency from 17.7% to 22.8%,
decreases HC emissions from 3200 to 2300 ppm, and lowers
CO emissions from 3.6 to 0.25%
by volume when compared
to the normal engine (CR=7.4, A/F=13.2) at 2 kW, 3000
rpm. Ignition delay was lower, combustion duration was
shorter, and cylinder peak pressures were higher with the
copper catalyst at higher compression ratios and with leaner
fuel-air mixtures. Knock-limited power output also increased
by about 12% at a high CR of 9:1 in the presence of copper
catalyst..."
https://digital.library.unt.edu/ark:...dc740511/m1/8/
There's interesting stuff in the rest of that paper too.
Now coating pistons, valves, intake tracts with copper is as easy as a Copper Sulphate solution and some copper wire.
(I played with this as a kid)
Nice too see some vindication of the idea..?
The Following 4 Users Say Thank You to Logic For This Useful Post:
freebeard (09-25-2023), Isaac Zachary (09-25-2023), Joggernot (09-26-2023), pgfpro (09-23-2024)
