Old 09-28-2023, 11:34 AM   #20 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Not sure what insulated surfaces inside the chamber would actually get you as a benefit
A theoretical insulation on all surfaces that doesn't exist, at least not yet.
I did put a ceramic thermal barrier on the tops of my pistons and in the combustion chamber and in the exhaust ports on the Bug. But then I had a hard time getting the engine temps up to where they needed to be. Even after bypassing the oil cooler I still would hardly see oil temps above 150 °F IIRC (they never would get to 180 °F).
The Following 2 Users Say Thank You to Isaac Zachary For This Useful Post:
freebeard (09-28-2023), pgfpro (09-23-2024)
