Old 09-28-2023, 11:39 AM   #25 (permalink)
Piotrsko
You're in Cali where it's illegal to set your pump to either over supply or short supply +/- some small percent. They also random test stations in unmarked vehicles constantly and I have seen the affects of failing to properly set the pumps: the station gets closed.
Cant see a station setting the pump for free fuel just as a business practice, doesn't make sense.
Lotta variables you could be missing, formulation, air density, temps, loose step ring wheel nut.......
