Old 09-28-2023, 04:42 PM   #9 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
I'm assuming you are looking to reduce unspring and rotating weight? An easy way to do that would be to turn down the rotors to their minimum thickness. If you want to go further there is the option of drilling. The machined rotor material itself that contacts the pad and the area around the mounting holes for the wheel studs.
Bolt brakes are larger than necessary because they are shared with the Cruze Premier.
