Old 09-29-2023, 07:45 PM   #40 (permalink)
JacobLeSann
Close enough? Comes with horse
Here’s the aforementioned China buggy. Upside down because I believe in neck mobility. Lots of 30 MPH fun until you run out of gas in like 10 minutes. The tank is as small as my scooter’s while the engine is likely 150-175cc. It’s a solid axle rear with a big Chinese scooter engine mounted to a china drive R/N/D gearbox. It must be a 4 stroke as it’s pretty weak. Only vehicle to date that I have ran out of gas in. It’s been parked since it did this cool trick where the CVT belt fell apart after starting it.
It’s not very heavy, as I can lift either end easily. The frame is pretty poorly designed and some of the running gear just makes no sense.
I still have several Nissan LEAF battery cells that I never used, maybe this could be a nice electric project. Got it for free. Maybe I’ll make a thread someday on it.
Mini Ford RS200 Cosworth?
ID:	34208   Click image for larger version
The Following User Says Thank You to JacobLeSann For This Useful Post:
Joggernot (09-30-2023)
