Originally Posted by cRiPpLe_rOoStEr
I guess the example provided by Isaac Zachary regarding spare tires and chains may be even worse for the average Joe than engine access, considering most people won't me so mechanically-inclined to perform a DIY repair, even though an engine with poor access might increase the time spent for a repair and increase labour cost.
Toyota said the engine and transaxle should be removed on the Avalon in order to change the swaybar bushings.
I was able to force my arm back in there with a wrench and back out the bolts enough to slide the bushings out from their brackets.
Not a great design, but at least it did end up being quite quick and cheap to do by doing it DIY.
Now I'm looking to go get a replacement engine for the Prius... Ooooooohhhh Boy!! Here we go!!
