Old 10-13-2023, 05:20 PM   #61 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
My take on it is this:
  1. You have a twisting force that causes the side walls to flex.
  2. At the same time you have more downforce due to inertial forces caused by acceleration, which makes the tires squat.
  3. Does this really reduce the radius and thus increase torque? Of this I'm not certain, as with every turn of the wheel the outer circumfrence of the tire does not change and therefore you get generally the same distance per turn with or without the sidewall flex.
  4. We are dealing with flexible structures here (tires) and trying to apply the math that applies to solid ones (force x radius). But maybe it's more like a pulley (small diameter wheel pulling on larger diameter wheel).
