Old 10-22-2023, 05:42 PM   #167 (permalink)
Xist
I am glad that we are already rid of alanstatener.
Meanwhile, this is what Google Bard said on the topic:
Building a greenhouse out of coroplast is a great way to create an affordable and durable structure for growing plants. Coroplast is a type of corrugated plastic that is lightweight, easy to work with, and resistant to weather and pests.
Materials:
Coroplast sheets
Wood or metal framing
Screws or nails
Door hinges
Ventilation vents
Caulk or sealant
Instructions:
Build the frame of the greenhouse. This can be done using wood or metal framing. The size of the frame will depend on the size of the greenhouse you want to build.
Cut the coroplast sheets to size. Use a utility knife or circular saw to cut the coroplast sheets to fit the frame.
Attach the coroplast sheets to the frame. Use screws or nails to attach the coroplast sheets to the frame.
Install the door. Cut a hole in the coroplast for the door. Attach the door to the frame using door hinges.
Install ventilation vents. Cut holes in the coroplast for ventilation vents. Install ventilation vents in the holes.
Seal any gaps or cracks. Use caulk or sealant to seal any gaps or cracks in the coroplast.
Tips:
Orient the coroplast sheets so that the corrugations run vertically. This will help to strengthen the structure.
Use a variety of screw or nail sizes to attach the coroplast sheets to the frame. This will help to prevent the coroplast from tearing.
Be sure to install ventilation vents in the greenhouse. This will help to prevent the buildup of heat and humidity.
If you live in an area with high winds, you may want to consider adding additional bracing to the greenhouse.
Benefits of a coroplast greenhouse:
Affordable: Coroplast is a relatively inexpensive material, making it a cost-effective option for building a greenhouse.
Durable: Coroplast is resistant to weather and pests, making it a durable option for a greenhouse.
Easy to work with: Coroplast is lightweight and easy to cut, making it a good option for DIY projects.
Insulating: Coroplast is a good insulator, which can help to keep the greenhouse warm in the winter and cool in the summer.
Translucent: Coroplast allows light to pass through, which is essential for plant growth.
Drawbacks of a coroplast greenhouse:
Not as strong as other materials: Coroplast is not as strong as other materials, such as glass or polycarbonate. This means that it may not be able to withstand heavy winds or snow loads.
Can be damaged by heat: Coroplast can be damaged by heat, so it is important to be careful not to place it in direct sunlight for extended periods of time.
Not as aesthetically pleasing as other materials: Coroplast is not as aesthetically pleasing as other materials, such as glass or polycarbonate.
Overall, coroplast is a good option for building an affordable and durable greenhouse. However, it is important to be aware of the drawbacks of coroplast before making a decision.
You definitely need to use roofing screws to install it.
Do you remember when I asked the torque specs of coroplast?
It is too easy to overtorque it and then the plastic under the washers breaks, so I think that the ideal washer is 1.5", the same width as the 2x4 into which you are screwing it.
The drawbacks are annoying and should have been written like this:
Remember, kids!
Don't place your greenhouse in direct sunlight!
