Old 10-26-2023, 12:07 PM   #195 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Yah, it's been a while since I last updated this...
Mainly, I've been enhancing the debug monitor portion of my code, and that has enabled me to discover a number of previously undetectable bugs within my code that had been there for years. Stuff like, tank average vehicle speed going wonky after 500 miles traveled, or fuel cost causing excessively high speeds and fuel consumption rates, or CPU utilitization being artificially reported low. Also pushed more global variables into arrays - this enables visibility to the developer via the debug monitor, and also uncovered a few more very subtle bugs.
Now I am in the process of modifying the signal simulator part of the debug monitor to simulate a peak/hold injector signal, which will in turn allow me to modify the fuel injector monitor code to properly detect and process a peak/hold injector signal. I will use as a base that peak/hold injector code first develped here and incorporated into both meelis11's and abbalooga's code.
