Old 10-29-2023, 04:10 PM   #23 (permalink)
freebeard
Maybe you need to upgrade the hardware?
https://www.tomshardware.com › how-to › install-windows-11-raspberry-pi
How to Install Windows 11 on a Raspberry Pi 4 | Tom's Hardware
What you will need to install Windows 11 on a Raspberry Pi 4. Raspberry Pi 4 4GB or 8GB; An 32GB or larger SSD via a USB 3 caddy.Best for performance or 16GB or larger microSD card, (see best ...
https://www.tomshardware.com › how-to › install-windows-10-raspberry-pi
How to Install Windows 10 on a Raspberry Pi 4 | Tom's Hardware
1. Download the latest pre-release version of WoR tool https://www.worproject.ml/downloads and extract the files. 2. Visit the Windows on Raspberry Pi Discord server and go to the Downloads...
Then use the GPIO header:
https://www.abelectronics.co.uk › kb › article › 1035 › serial-port-setup-in-raspberry-pi-os
Using the serial port on Raspberry Pi - AB Electronics UK
4 days agoThe Raspberry Pi contains a UART serial port on the GPIO header on pins 8, TXD (GPIO 14) and 10, RXD (GPIO 15). The UART port can connect directly to a wide range of devices using 3.3V UART pins or a serial interface to convert the UART voltages to an industry standard such as RS232 or RS485.
https://pimylifeup.com › raspberry-pi-serial
How to Handle Raspberry Pi Serial Reading and Writing
Jan 30, 2022Wiring your RS232 to TTL adapter to your Raspberry Pi is a simple process, with it requiring only 4 of the GPIO connecting to be wired to the serial connector, even better all 4 GPIO pins needed are in a row, so it is easy to follow. Make use of our table and guide below to connect your
You can't be wise and in love at the same time. -- Bob Dylan
