Old 10-30-2023, 11:59 AM   #21 (permalink)
wax87
wax87's Avatar
none - '23 Ford Maverick XLT
Originally Posted by Logic View Post
This is just a crazy idea I had and thought I'd put 'out there':
Take your well run in manual gearbox apart.
Wrap thick copper wire around each gear and discharge a large capacitor through the wire to magnetize the gears so the tops are north and and the bottoms south. (not left north and right south. Although that may work too)
Now all the gears are magnetized such that they repel each other when the box is put back together.
Due to the very small gaps between gear teeth the repulsive force should be substantial enough to avoid gear tooth contact a lot of the time, and greatly decrease the pressure with which the teeth push on each other all the time.
I have no idea how much difference this would make?? Research Reqd!
You'd still have to add oil. (drag. maybe thinner oil?)
Then there's the issue of all that fine metal that usually accumulates on the sump plug magnet! On a well run in gearbox..?
It'd be great if some one here knows the maths in this and can chip in so I don't have to go look it all up!
Try it on a bicycle chain and sprocket
