'Ford Transit'
The model year 2024, Transit 'Connect' BEV van in on sale in Europe today.
It's a complete redesign. AUTOCAR and other websites are reporting:
* 15mm lower.
* A 13% lower drag coefficient, @ Cd 0.319.
* It's height is under 2-meters.
* Above 30-mpg equivalency.
* 200mm added length.
1) If we accept the published Cd 0.319, and a delta- 13% drag, then the outgoing model must have had Cd 0.3666.
2) If the OEM top speed was 80-mph, a 13% drag reduction ( according to Dr. Wolf-Heinrich Hucho's math, would be good for 83.46-mph top speed.
3) By the same metrics, achieving a top speed of 110-mph, from 80-mph would require Cd 0.2153.
A) Just for ----- & giggles, if we allowed a cooling system drag delete of Cd 0.025, that would get us to Cd 0.3416.
B) If the 2024 Connect's front air curtains were a 'new' modification, we might allow a delta-Cd 0.010 ( BMW ), which could get us to Cd 0.3316.
C) And then the difference of delta-Cd 0.0226, for a complete flat underbody of an electric van might explain the remaining drag discrepancy, down to the reported Cd 0.319 ( which would not be unreasonable, as a diffuser by itself can deliver a delta-Cd 0.020 ).
The arbitrary change of the Transit's front and rear height is problematic as far as attributing differences in performance. Historically, even, what would seem to be very small changes to a vehicles 'inclination', can result in dramatic changes to drag.
Removing 10 out of 14 slats from a radiator shutter system is not sufficient to explain the top speed difference experienced. It's scientifically impossible.
We need to look elsewhere for the actual attribution.
