Old 11-16-2023, 04:45 PM   #16 (permalink)
freebeard
True, but in this context, that matters how?
High dynamic loads in a public roadway?
Let's compromise -- a triangle, else two diagonals or four corner brackets for the square.
Why are you resistant to reducing the cross section? I suggested 1-2 thou, aerohead 0.008 #1 guitar string or piano wire.
I wonder if I could use .030 alum welding tig rod and run it thru a bead roller with angled rollers to seek a teardrop approx/improved shape?
Good luck with that. They will still need to be in tension and cross each other.
j-c-c (11-16-2023)
