Multi color by row, 1'Sq, assuming a 24"x12" frame, with 1.25" gap on each side to reduce frame interference, grid spacing allows 94% opening per square with .03" wire/rod.
I was also considering adding a spot of glue to the tuff ends to see if that might mass dampen/steady the tuff fluctuations.
Frame is at this point streamline tubing .45"x .27"
