Old 11-18-2023, 07:26 AM   #1 (permalink)
bwilson4web
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Pizza pan wheel cover testing
I'm going to call it a modest success:
  • thin green line - suggests the pizza pan wheel covers provide up to ~4% at 70 mph.
    • temperature adjustment - field benchmarks are subject to weather effects, notably temperature. With the covers on, the temperature was ~3F cooler. So I displaced the trend graph, mid-point to match the mid-point of the higher temperature benchmark.
  • ~$600 savings - a 4% improvement on a $15,000 Model 3 battery pack.
  • unexpected impact of cold - comparing the 63F to 48F, the curves are similar but significantly offset. The colder air should have been about 3.5% denser which was my expected drag offset. Also, it was not uniform across the speed range suggesting at least one other, non-linear, temperature based, mechanism is in effect.
    • The shape of the energy loss curve showed as much as a 25% loss at slowest speeds and ~10% loss at highest speeds. This suggests a loss of energy relative to the drive energy of something like heating that would show an outsized effect at lower speeds where less drive energy is needed. I did get the cabin setting to 71F, windshield and feet, and lowest fan setting. I consider interior windshield heating a hard requirement to avoid condensation from our breathing. This bears future investigation.
Significant cross country drives Monday through Wednesday with the covers on will give the battery management system more samples. This will hopefully update the projected ranges as a function of SOC.
My end goal is to compensate for the ~10% battery degradation and recover my original 240 mi range. A potential 4% reduction in drag energy is a step forward.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
The Following 5 Users Say Thank You to bwilson4web For This Useful Post:
aerohead (11-20-2023), Cd (11-19-2023), freebeard (11-18-2023), Joggernot (11-20-2023), Piwoslaw (11-18-2023)
