Old 11-21-2023, 06:50 AM   #8 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by Isaac Zachary View Post
I need to do some testing, but just from experience:
  • Without the block heater connected the engine will be some 10 degrees or so warmer than ambient in the morning. If it's -30 °F the engine will be like -20 °F. It takes several minutes for the heater to start putting out any heat.
  • With the block heater connected all night long the engine will be some 30 to 40 °F warmer than ambient. So on a -30 °F day it's not that much better than 0 °F still. It still takes several minutes for the heater to start putting out any heat.
I do have a 1,500W circulating tank block heater that I want to install. The problem is finding places to attach it. I either need a 120V pump that's connected to the same plug as the heater so coolant always flows through it when it's on, or I need to modify the thermostat housing for a place for coolant to flow out towards the circulating heater, with a T up on the upper radiator hose.
-30°F is a lot colder than what I experience in NY! I would use my block heater at temps like that! Below 0°F is rare here.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
