Old 11-22-2023, 08:20 AM   #797 (permalink)
IRONICK
IRONICK's Avatar
Originally Posted by Phase View Post
The fins are officially on! Drilled in at 3 points with double sided 3m vhb mounting tape along the edges between drill points. Letting it sit over night so mounting tape adheres better before driving. I need a heat gun to curve the plastic inwards to add a taper. The plastic is much harder to shape than poster board or cardboard clearly
It is not necessary to make them pointed at the back, to have that V shape.
If you wanted to take into account the integration in the design of the car, you have to start from the middle of the stoplight, where the edge of the stoplight ends.
Anyway, it looks neat, compared to other changes seen on the forum.
