The aeromods look great ! ( functionally of course
Great to see some bold modifications.
Thanks for sharing the actual results, rather than just sharing the good points.
Do you have a small video camera to do tuft tests with ?
I came across some small "dice" mini cameras for less than $15 that are small enough to even fit in an inner wheelwell.
At that price, you could have several to test multiple areas at once.
https://www.walmart.com/ip/Mini-Cube...mory/906337644
One other thing I came across that might be helpful is a 3d photogrametry app called KIRI.
I did an extremely crude test of my car with it, and it picked up quite a few detailed areas on the car.
It built a 3d model of my car in 10 minutes that would take 25 -30 hours to model in a 3d program.
Once the model is built, you could run a sim in Airshaper to see where your trouble areas are.
I'm thinking of investing in some pressure testers like Julian Edgar suggested using.
Keep the posts coming ! I'm really liking what you are doing witg the car !
