Old 10-24-2008, 07:20 AM   #2 (permalink)
diamondlarry
EPA MPG #'s Slayer
diamondlarry's Avatar
La Forge - '07 Toyota Prius
90 day: 84.38 mpg (US)
DOHCtor Green MPG - '99 Saturn SL2
90 day: 49.17 mpg (US)
Silver Sipper - '00 Honda Insight
Most of the cars that do that start using fuel again when the rpms reach somewhere near the normal idle rpm. The only times you should use DFCO is if you have mis-judged the distance to the stop light and are coming in too hot or if you are going down a hill that is long enough to build up too much speed. In the case of the hill, you may even have to start downshifting.
