Thread: Eco racing?
Old 12-04-2023, 11:57 AM   #6 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
I wonder if a car using an electric motor to drive with just the right size battery and generator to load level the power per lap. A dual motor setup might be better for regen braking front and rear. This way you use a higher hp electic motor and a lower hp generator, but the generator runs at peak BSFC. The battery supplies the accelation surge energy, and recharges braking and in the corners.
So say you took a model S plaid and removed about 4/5 of the battery. Replaced that weight with a 1.5 l turbo Honda engine making 205hp running a generator. So for a few seconds say 5 you use 1000hp, then your generator needs the 5 you accelerate, plus 20 more seconds to recharge the power used. The braking regen could cover the charging losses. Then you can accelerate again with 1000hp
